Looking for Mills MLB # 1291
Is there a listing for Mills part numbers ?
Did each number get assigned to a particular part ?
mechanic wrote:Hi The part you are looking for is the top casting for a Mills COK gooseneck. No one has a listing of all Mills or any other manufacturers part numbers, even Krahl assigned his own numbers to many of his parts. All Mills and other manufacturers had a number for every part, however many parts did not have a number stamped on them.
mechanic wrote:Thats an original skill stop cover for a Mills COK. Used to cover the casting when the skill stops were removed. However this part was never plated just polished, the plating is more recent. You don't see too many skill stop covers.
sam2002 wrote:mechanic wrote:Thats an original skill stop cover for a Mills COK. Used to cover the casting when the skill stops were removed. However this part was never plated just polished, the plating is more recent. You don't see too many skill stop covers.
Awesome ! I was leery to run it through a drill press and punch out the holes .
ah the search goes on .
Thank you
