rilaw wrote:Just rolled two cherries and a plum, no payout.... Dropped another nickle in, pulled out... Stuck, halfway.... Tried pulling hard, no go..... Where do I go from here?
radiorich123 wrote:HI
This is a problem with jamming on the vest pockets. I find using worn nickels work best. Looks like you may have a nickel jam on the bottom of the coin tube.Try turning the machine upside down and remove the jam in the tube.Hope this helps you. Any body have other ideas ?
Rich
