mills skill stop system
Re: mills skill stop system
Postby gsx11r » Sun Aug 07, 2016 12:32 pm
Hi Jeff
Look on the link above.
This is my two original FoK.
The two have fake skill stop ! That was a modification just for the Police .
Stephane
gsx11r
Postby JHSS-1944 » Tue Aug 09, 2016 3:10 am
newly made parts
My new parts so far. with a few extras, do to my change in the thickness.
have just loaded my first photo ...Happy Happy ,Joy Joy !!!
Jeff H.
Postby gsx11r » Thu Aug 11, 2016 1:01 pm
Hi Jeff
Very nice Job !! and very fast !! Congratulation !!! =D>
For info , your mechanism is from a First version of the COK !
This is two file who will maybe help you for finish your projet !
Courage !! Nearly the end , and hope to see more photos nearly !
Stephane
And be sure that your 3 buttons have the good position !!
gsx11r
Postby JHSS-1944 » Fri Aug 12, 2016 1:34 am
Stephane ;
thank you again for your time with this project !
need to tweek a few things with the parts I made first.
I have made all of the parts ,including the 2 other shoes.
need to correct the spacing of the shaft & spacers..... made every thing a little longer on purpose. need to weld shaft to bracket also. will make a "plastic" bracket first to ensure position on the 2 screw holes on it.
will keep everyone updated.
Postby JHSS-1944 » Wed Aug 17, 2016 2:26 am
up date on my new parts. been very busy but, getting closer to getting it done.
Postby Richard13 » Wed Aug 17, 2016 5:05 am
All in a say is wow. Better make a second set after first one is in and working. You could probably sell it! Good job.
Richard13
Postby JHSS-1944 » Thu Aug 18, 2016 12:48 am
I have a partial set already, thinner materials first chosen.
will get t done soon.
Postby JHSS-1944 » Thu Aug 18, 2016 2:26 am
otay;
so far..... with rivets installed.
when I can find the time..... bend the 3 push lever ends over, screw the stop lever connections to the stop lever links.
position the push lever bracket to the frame. monkey with that a bit , mark the hole placement ,ect.
jeff
Postby Mills » Thu Aug 18, 2016 4:54 am
Good work !!
Bravo :D =D> =D>
Mills
Postby JHSS-1944 » Sun Aug 21, 2016 2:41 am
BANG !....... DONE !
Finally got it installed (now 2 A.M.). found a few other issues first. the 3rd reel was a bit loose, reel tins 2 & 3 bent, so rubbing on the new parts. had to bend the bracket a little forward. when shaft was welded on ,the heat bent it just enough.
the big issue, hole placement; figured it out, put a C-clamp to hold it, play it ,ect. but now the mechanics won't fit in place with the clamp still on !! wanted to be sure the button were exactly above. figured out something to hold it , then into the cabinet , well the buttons were way far ahead.
re positioned the whole thing. then it moved pulling it out of the cabinet !!!!!
Finally got the 1 hole drilled & screwed in , then recheck the position again , & again off a bit.
got that right, drilled the 2nd hole. hand bent a few pieces (just to do it). actually works too !!!!
took the part set out to paint. added a shim to the reel bundle (to avoid rubbing) played with a few other things.
all the other parts present were bent over the years also, part of the rubbing on the reel tins.
all new parts in flat black paint ,except the 2 screws (I forgot).
PreviousNext
