Mills Check Boy sold
Re: Mills Check Boy for sale
Postby Chris » Wed Nov 02, 2016 1:47 pm
Here's pics of the pin adjustment. Located on the very back RT . You can move this lever 1 of 2 positions...and pin it.
This moves the "Lock in Lever" that stops the wheel . Notice there's 2 stop/ cog wheels attached to the wheel.
What is this adjustment for ?
Chris
Postby Chris » Wed Nov 02, 2016 1:51 pm
Here's picture of the gaffs / cheaters / or blank-outs that are on a couple of the "payout" wheels.
Chris
Postby Richard13 » Wed Nov 02, 2016 3:42 pm
It looks like I will have to pull mine out and try to pin that back and see what happens. Nice bugs in there I wonder if it's the high roller $2 dollar payout that was bugged. Might not get to it tonight there is some ball game on everyone is coming over to watch and I have to clean up and start cooking. If you pin yours and test it let us know what happens.
Richard13
Postby Richard13 » Sat Nov 05, 2016 3:38 pm
Hey Chris I think I figured it out mine has a cotter key in the hole for that lever you were asking about. I pulled the pin and moved the lever over after trying to line up the huge payout with no luck.
Then I ran the mechinism again after lining up the payout lever on the 40 coin win and it dumped 40 buffalo nickels! Here is a close up of the star wheel or star gear. You can see the payout indent with the punch mark next to it is much smaller than the rest of the "teeth" on the star gear. Several of the other indented teeth on that same wheel are also shallow cut!!
So when the tooth selector hits star gear with lever pinned to inside position AND pay out wheel lined up to pay it does not pay. Maybe it is for manual payout of tokens or something?
Richard13
check boy
Postby Chris » Fri Dec 02, 2016 1:51 pm
Any interest ?
Chris
