Would not consider a fantastic Find, But just picked this up
Re: Would not consider a fantastic Find, But just picked thi
Postby berardini21 » Mon Jan 16, 2017 4:07 pm
Ok, jackpot area was filled with tissues to stop it from filling up, there was a broken spring inside a fairly large spring I believe it has to do with the arm mechanism, counter is not working. Fixed the not paying out on the oranges, part of the counter was in the way. Coins are not going into slug tray, they are cycling correct. I could be wrong but don't these things spit out a token when you hit the jackpot ? I'm trying to find where it would be ? Thanks in advanced
berardini21
Postby JHSS-1944 » Tue Jan 17, 2017 1:32 am
Nice find for sure (via the price). interesting that the pump is missing. pays out is in coins (not tokens.)
sounds like you have a handle on all it's little issues.
actually the high top you have seems to be more interesting to me (I own a black cherry). odd ball being in "brass".
I assume you will resell eventually ?
