briank wrote:What controls the duration that the payout fingers are held back? Seems as if you pull the handle within a split second the payout fingers are released and they stop the reels. If I could figure that out...its not the drag I guess .its thw fact they aren't being held back sufficiently. Its almost the same as when I got my caille sphinx but the problem on that was the hydraulic pump.......this machine does not have that. Clock mechanism seems to work fine??
