Mills Cherry serial number
Postby slotorama » Tue Jul 04, 2017 8:20 pm
I am looking at a Mills Cherry, not the bursting cherry, the other one. It is a 2 cherry payout. I was wondering where the serial number should be. the guy who is selling it states it is on the wood in the back...is that where it should be for this type of machine?
slotorama
Re: Mills Cherry serial number
Postby mechanic » Wed Jul 05, 2017 11:34 am
A sticker should be on the left side when looking at the machine from the back. The matching number should be on the mech base in the front of the machine. You will need to pull out the mechanism to see it.
Postby edgeCity » Wed Jul 05, 2017 4:13 pm
My 10c Black Cherry, which I believe is original,
has the (matching) serial numbers 'embossed' on the rear of the wooden base (hard to see!) . . .
. . . and on the tag that's affixed to the inside of the case (handle side) . . .
. . . hope this helps!
Nelson
edgeCity
Postby mechanic » Wed Jul 05, 2017 5:07 pm
edgeCity wrote:My 10c Black Cherry, which I believe is original,
Nelson
The serial numbers are not always on the wood base. It is an added identifying mark but without the matching sticker on the mechanism base anyone could put a random mechanism into the cabinet. Old operators did do swaps and I have seen non-matching serial numbers over the years.
Postby edgeCity » Thu Jul 06, 2017 4:29 am
" . . . without the matching sticker on the mechanism base anyone could put a random mechanism into the cabinet."
Aha! I see the sticker labelled 'Bell Family Mechanism No.' . . .
Sadly, it is so soaked with grease that the serial number is virtually unreadable.
Do you know of a way to clean the label without erasing what's stamped on it?
Thanks for pointing this out!
edgeCity
Postby oldtimeslots.com » Thu Jul 06, 2017 9:33 am
Hi edge city, I use a half sheet of Bounty paper towel and fold it down so it is slightly larger than the Mill Novelty label, soak it very well with a heavy Dawn dish soap and warm water and lay it on the label overnight and you will be amazed that it lifts the grease out of the label exposing the serial number. You might put a little weight on it to soak it in.
Good luck!
oldtimeslots.com
Postby Rockola » Thu Jul 06, 2017 1:39 pm
The hidden serial number left rear case upright,are they on all Black Cherry's you cant see it until you take the paint off
Rockola
Postby shortrackskater » Wed Mar 14, 2018 4:10 pm
Hi - commenting on an old post - I hope someone replies!
Regarding the last picture shown, of the serial number - where exactly is that serial number? It's such a close up that I'm not sure where to look.
My machine has a nice NOTCH in the back middle, where the serial number was. My stickers are gone but I can see the adhesive mark where one was.
shortrackskater
Postby shortrackskater » Sat Mar 17, 2018 3:44 pm
Anyone?
shortrackskater
Postby Imyourcaptain » Sat Mar 17, 2018 4:28 pm
Is there a number on the mech itself?
Imyourcaptain
