Jennings sportsman payout pin wiring
Postby clubconsoles » Wed Jun 20, 2018 12:34 pm
hi Guys
I am just overhauling the payout gear and i have a wire coming from the 12v trasformer that should go on one of these ten pins.
Alas the label fell off and don't know which one?????
I have numbered top left #1 thus bottom pin on RH side is #10.
The other wire from the transformer goes to the tilt relay on the playboard.
Can anyone advise??
clubconsoles
Re: Jennings sportsman payout pin wiring
Postby clubconsoles » Wed Jun 20, 2018 12:35 pm
I should add its not pin 9, that was already free!
clubconsoles
Postby clubconsoles » Sat Jun 23, 2018 1:29 pm
figured it out now by trial and error and a good supply of 5 amp fuses!
Was a wiring diagram ever available for these?
I download a copy of the original manual from the sands museum website but that just talks about the mechanical sequence of operation.
clubconsoles
