Mills FOK Vender payout short on larger wins
Postby SnootyDrinkingRoom » Tue Dec 18, 2018 6:46 pm
I’ve noticed that when I hit wins of 8 or more on my Mills FOK Vender the payout is short one coin. So, two cherries pays 2, two cherries then lemon pays 4, three oranges pays 7 ( should be 8 ) three plums pays 11 (should be 12) etc.
Any idea where to start to troubleshoot this? Please explain like I’m 5. I’m new to vintage slots and I still have a long way to go to learn what everything is called and how the mechanism works. I guess this is a good place to start.
Here’s a couple Imgur albums from when I had the mech out of the box:
https://imgur.com/gallery/4F3XXdH
https://imgur.com/gallery/iwchkg7
Thanks!
SnootyDrinkingRoom
Re: Mills FOK Vender payout short on larger wins
Postby kentdun » Tue Dec 18, 2018 6:59 pm
The payouts are paid by thickness. If you are using newer nickels it can affect payouts. Older coins are a bit thinner.
There is probably an older thread on this topic.
kentdun
Postby SnootyDrinkingRoom » Tue Dec 18, 2018 7:02 pm
It does make sense that the payouts go by thickness. Are newer quarters thicker than their 1920’s counterparts? I forgot to mention that it’s a quarter machine.
Also, is this adjustable? Or just something that we must accept if playing with modern coins?
SnootyDrinkingRoom
Postby radiorich123 » Tue Dec 18, 2018 7:12 pm
I use old buffalo nickels and then the pay outs are correct.
Rich
Postby kentdun » Tue Dec 18, 2018 7:23 pm
Not sure if new quarters are thicker. Quarters of the day were silver and wore down faster. It might take a bit of investment filling it with older silver quarters. Ones with the dates worn off would be cheaper.
kentdun
Postby marsonion » Wed Dec 19, 2018 12:40 am
kentdun wrote:Not sure if new quarters are thicker. Quarters of the day were silver and wore down faster. It might take a bit of investment filling it with older silver quarters. Ones with the dates worn off would be cheaper.
Yes, I believe modern quarters are thicker, because I get shorted on the "16 for 1" payout on my Mills Dice machine: only 15 quarters come out. :cry: Also, my 25c Caille Grand Prize runs toward shorting the higher payouts in much the same way as the OP describes, though it was explained to me that that could be due to the machine possibly having been originally manufactured for the French market (the 1 Franc coin being the same diameter, but thinner, than the US 25c piece). So I don't know what to do about fixing payouts on old 25c denomination slots-- aside from buying lots of the now-very-expensive antique junk silver quarters as suggested above. But I have found a strategy for getting proper payouts on old nickel machines, by mixing in some really old, flat "V" nickels with the modern coinage: one oldie in every four or five nickels played results in correct payouts.
Postby RameGoom » Wed Dec 19, 2018 3:13 pm
^^ Solved! Change the payout numbers on the card...!
RameGoom
Postby kentdun » Wed Dec 19, 2018 4:04 pm
Some payout cards listed a range of payouts. 2-4 , 7-9, etc. Covered the operator for short payouts.
kentdun
Postby marsonion » Thu Dec 20, 2018 8:29 pm
kentdun wrote:Some payout cards listed a range of payouts. 2-4 , 7-9, etc. Covered the operator for short payouts.
Which may have been a necessity because, by 1939, any slot player would likely have been carrying a random mixture of the three varieties of five cent coins shown here. Look how our money has grown! For an orange/ten payout, there was nearly a 1/8" cumulative difference across 25 years for the coin slides to accommodate. I hope someone possessing a nice collection of original Washington quarters (1932-1964) will post a similar comparison with the post-1964 equivalent... I've only got three of those junk silver quarters handy.
