Pace Comet skill stops
Postby capt7310 » Tue Mar 05, 2019 7:15 pm
Just picked up a pace comet with the skill stops, the push downs are still there with the springs and they work fine. I'm trying to figure out what's missing and how they work. If someone has a photo that would help. Thanks
capt7310
Re: Pace Comet skill stops
Postby MONTI » Wed Mar 06, 2019 10:11 am
capt!
I hope this parts blow up helps sorry for the poor image but it is from an original Pace parts manual in black and white and poor quality to begin with!
These parts will probably be very hard to find as most route operators of the day would remove them and throw them away and reproducing them would be a real challenge as well!
In my 35 Plus years of doing this I don't believe any one ever reproduced these parts but I may be wrong!
Someone out there may know!
Postby gsx11r » Wed Mar 06, 2019 10:53 am
Hi
If this can help you !
https://retro-jackpot.fr/pace/comet-blanche
https://retro-jackpot.fr/pace/manuel-technique
and just for Fun :
https://retro-jackpot.fr/pace/kit-selector
And post some photo of your Pace . More easy for tell you what you need .
Stephane
gsx11r
Postby MONTI » Wed Mar 06, 2019 12:40 pm
gsx11r wrote:Hi
and just for Fun :
Stephane
Well Hello Stephane!
We haven't spoken in a while, Hope All Is Well Across The Pond!
Great Links as Usual!
Ciao!
Postby sam2002 » Wed Mar 06, 2019 12:43 pm
Here are some pics from my mills pace comet .
Machine is for sale . Its a bit of a project . Needs some minor adjustments on the jackpot . Also needs a weld on the top casting . Needs back lip and cash box . Original tin strips . Skill stops work . Vender works . Mech pays and plays as it
should .
Postby capt7310 » Thu Mar 07, 2019 4:38 am
As always thanks to all. And as Monti posted don't think I'll find those parts and I think if I did might be out of my wheelhouse trying to put it together..However, Sam I'll call you later your machine is the exact one I just bought and maybe I can make one perfect machine from the 2.....Thanks again
capt7310
Postby capt7310 » Thu Mar 07, 2019 6:47 am
Sam thought the pic looked different here's mine machine. I think I'm stuck with what I have no skill stops. thanks again
capt7310
Postby sam2002 » Thu Mar 07, 2019 9:42 am
Best of luck with the machine . Keep an eye out parts may show up !
Postby MONTI » Thu Mar 07, 2019 10:16 am
Capt!
If I was you I would consider following thru with Sam a bit as even though the castings are different in design with the reel skill stops being located on the upper casting above the reel windows the mech and/or parts may be interchangeable!
The coin heads are different so a direct mech swap would not work but the skill stops may be interchangeable?
Probably should see better pictures of both mechs from the same camera angles for comparison!
If your not worried about complete originality it could be do-able?? Maybe??
Any other comments out there?
Just a thought!
Postby gsx11r » Thu Mar 07, 2019 1:30 pm
Hi
It s me again.
(Hi Monti, I m always alive even we have a lot of yellow jacket near the home. :D )
For info , the slot from Sam is a Mills FOK, with a Pace comet front casting. It s not original but a modification for add a jackpot on a FOK
Look here:
https://retro-jackpot.fr/mills/fok/f-o- ... C3%A9es-20
Impossible to swap any parts of the Mills FOK/Comet with an Original Pace comet !!
Sam , if you can add photo feom the front mecanism , I would like to know how work the jackpot and link in the FoK/Comet.
For info again , there are a lot of Pace comet in France.
Capt , if you wait about a reply about your missing parts , why don t post a photo of the mech.? :?:
Stephane
gsx11r
Users browsing this forum: Google [Bot] and 17 guests
