Hound and Hare Conversion Front
Postby tsparts4u » Fri Sep 13, 2019 2:53 pm
Hi,
Just wondering if anyone on the forum might have a conversion front Hound and Hare machine with an award card. This is an FOK style casting.
If possible, I need a picture of the award card and some dimensions so I can reproduce this card for someone. Any help would be greatly appreciated.
Thank you.
Jerry
tsparts4u
Re: Hound and Hare Conversion Front
Postby mechanic » Fri Sep 13, 2019 4:06 pm
Can you post a pic of it? I have some rough cards, maybe we can help each other. Later Jim
Postby tsparts4u » Fri Sep 13, 2019 4:25 pm
Hi Jim,
Thanks, for your reply.
Here are pictures of the Hound & Hare slot and award card found online.
Regards,
Jerry
Hound and Hare Award Card.jpg (19.3 KiB) Viewed 7304 times
tsparts4u
Postby mechanic » Fri Sep 13, 2019 8:32 pm
Jerry I think the bottom pic is the same as mine. It's on plain paper and if I remember correct will need retouching. Do you have a way to retouch cards? I may have another partial which could be used if needed. Let me know what your thinking. By the way nice hound n hare looks like mine, with award card issues.
Postby tsparts4u » Sat Sep 14, 2019 3:14 am
Hi Jim,
What I need to make a new award card, are sizes of the 3 openings, the width of the spacing between the openings, and the wording
on the bar symbols. The rest of it I'm pretty sure I can duplicate. However, a copy of an original would be even better to work with. Even if it it would be on plain paper, and folded to fit in a regular envelope.
tsparts4u
Postby mechanic » Mon Sep 16, 2019 2:31 pm
Jerry I found the ones I have that need retouching and I have one more but I think it's worse they are all water stained. So I can send exact size copies of these to you. Two are FOK style and the small one is standard type. Can you get them retouched so they look better? If so let me know and we can go from there. Later Jim
Postby tsparts4u » Mon Sep 16, 2019 2:50 pm
Hi Jim,
That's great news! I believe that we can help each other out.
I don't actually have that machine. I recently received a request from someone that needed that award card, and I didn't have it.
My info.....
Jerry Fluegel
12254 W. Larkspur Road
Franklin, WI 53132
Regards,
Jerry
tsparts4u
Postby mechanic » Mon Sep 16, 2019 5:31 pm
Jerry Did you say you can retouch the award cards? If so I will send you laser copies of the 3 I have if you could send me 3 retouched ones back. Later Jim
Postby tsparts4u » Mon Sep 16, 2019 6:21 pm
Hi Jim,
I will clean up a card and make 3 copies for you, and I will return whatever you send me. There will be no charge except for return postage.
Regards,
Jerry
tsparts4u
Postby mechanic » Mon Sep 16, 2019 6:36 pm
Jerry Anything that improves on these is a good thing. Keep extras for yourself as there are more out there than you think. About 7 in my area alone. Thanks send them out by Wed. Later Jim
