Recently acquired a mills slot machine and need help
Postby Mferguson7985 » Mon Apr 06, 2020 1:32 pm
This was my grandfather's and I am unsure if anything is wrong with it. It is locked up and I've tried just the basics to get it to turn. I'm located in Oklahoma City if anyone knows of anyone or can help. Thank you.
Mferguson7985
Re: Recently acquired a mills slot machine and need help
Postby BALTMANHD103 » Mon Apr 06, 2020 2:01 pm
I fixed one for a gentleman recently and found it to be a jamed coin near the bottom really look it over close.
BALTMANHD103
Postby Mferguson7985 » Mon Apr 06, 2020 2:34 pm
I have looked at other mechs and I dont know if mine is missing parts or not? I dont know if it is complete.
Mferguson7985
Postby radiorich123 » Mon Apr 06, 2020 2:46 pm
HI
Send it to me and I will repair it for you. Located in New Jersey\
Richard
Postby BALTMANHD103 » Mon Apr 06, 2020 3:36 pm
If you want PM and I will talk to you about it and maybe I can talk you trough it sned me an email at baltmanhd103@yahoo.com. and I will give you my number. Did it ever work?
BALTMANHD103
Postby mechanic » Mon Apr 06, 2020 4:49 pm
You have at least 7 missing parts and a couple Sega parts added to the mech They do not affect the operation of the machine.
Postby Mferguson7985 » Mon Apr 06, 2020 5:03 pm
So as it stands it will not operate no matter what?
Mferguson7985
Postby mechanic » Mon Apr 06, 2020 7:22 pm
It should go even without some of the parts. Do you know how to cycle it outside of the cabinet?
Postby Mferguson7985 » Tue Apr 07, 2020 2:58 pm
I cycled it but the reels wont hardly turn.
Mferguson7985
Postby mazzeosa17 » Wed Apr 08, 2020 9:52 am
You're missing the main tension spring that belongs on the back of the machine, attached to the back frame on one side, and the operating fork on the other side. The mechanism usually won't have enough strength to turn the reels without that spring setup. If you get that spring, the reels should turn. See attached photo to see the spring you need from one of our vendors such as Dave Berten.
mazzeosa17
