Splits in cabinet
Splits in cabinet
Postby Shane » Mon Jun 07, 2021 2:50 pm
Looking for advice on solutions for splits in the base and sides of the cabinet (see pic).
The cabinet still seems structurally strong but would look better if the splits were smaller or gone. I don't want to take the cabinet apart.
Any recommendations on how to remedy or better to leave alone?
Shane
Shane
Re: Splits in cabinet
Postby radiorich123 » Mon Jun 07, 2021 3:43 pm
The splits are from the wood shrinking over time. The best way is to cut and glue thin veneer strips in the splits. Use walnut or oak veneer that match the original wood color.
Postby Shane » Mon Jun 07, 2021 4:04 pm
Thanks, Radiorich.
Would you recommend wedging strips into the cabinet as is or taking the cabinet apart?
Shane
Postby Steve Neul » Mon Jun 07, 2021 4:13 pm
I used to own an antique restoration business. What I would recommend is taking the cabinet apart and glue the pieces back together with dowels. Then if you are wishing to refinish it, sand the parts while you have it apart and then assemble it. Should then be good as new.
Steve Neul
Postby radiorich123 » Mon Jun 07, 2021 5:20 pm
Yes wedge and glue the strips in. I would not take the cabinet apart. If the cab finish is bad then strip it and refinish it. Here is a photo of one that i did.
Postby Shane » Mon Jun 07, 2021 6:07 pm
Looks great!
Shane
Shane
