Mills QT
Mills QT
Postby DennyW » Sun Aug 06, 2023 12:01 pm
I have a mills QT chevron and have a issue keeping nickel in place at the window it just falls down to the payout tube. Is there a spring needed to keep nickel in place?
Denny
DennyW
Re: Mills QT
Postby rtmccurdy » Sun Aug 06, 2023 5:39 pm
If I already addressed this on a Facebook thread I apologize. If you have the correct lever on the back of the coin head (different shape for 1 & 5 cent machines) and it has a spring attached then the issue is that the lever may be slightly bent or might need to be adjusted (filed a touch) to hold the nickel in place. In any case the coin head will have to be removed to make the adjustment. I also assume that the coin sensing pin is actually present and coming through the hole when the machine is cycled.
rtmccurdy
Re: Mills QT
Postby DennyW » Sun Aug 06, 2023 7:20 pm
rtmccurdy wrote:If I already addressed this on a Facebook thread I apologize. If you have the correct lever on the back of the coin head (different shape for 1 & 5 cent machines) and it has a spring attached then the issue is that the lever may be slightly bent or might need to be adjusted (filed a touch) to hold the nickel in place. In any case the coin head will have to be removed to make the adjustment. I also assume that the coin sensing pin is actually present and coming through the hole when the machine is cycled.
Spring is there, lever looks ok, and coin pin works.
I will take a closer look when I have time.
DennyW
Re: Mills QT
Postby DennyW » Mon Aug 07, 2023 1:05 pm
Found the problem the bottom tip of the spring lever that catches the coin has been filed down. :x
Other than that machine plays and pays as it should.
Denny
DennyW
