Handle Stuck
Handle Stuck
Postby midohioslotmachines » Sat Aug 31, 2024 7:39 am
I have a Jennings 50 cent Sun Chief Slot Machine, I was trying to sell. The buyer wanted me to test it. I pulled back the two fingers at the top of the mech. Pulled the arm, and worked fine.
I did that several times with no problem. After, I put a 50 cent piece in, the handle pulled half way down, now it is stuck. Most of these machines have been in storage for 20+ years. Have no knowledge
on the mechanisms, any ideas, Caroline Miller
midohioslotmachines
Location: 1627 Nantucket Drive Mansfield Ohio 44904 419.565.5684
Re: Handle Stuck
Postby NathanHollister » Sat Aug 31, 2024 2:46 pm
Jiggle the handle. Use the palm of your hand to strike the side of the machine to the left of where you dropped the coin in. Sometimes the coin gets stuck as it goes down to the escaltor and a solid strike will loosen it. Failing that, go here
https://www.youtube.com/watch?v=mHbJZ_TQwtw
NathanHollister
Re: Handle Stuck
Postby Swami » Sat Aug 31, 2024 3:18 pm
First you to have to free the handle. There is a ratchet on the side of the mech. Use your finger to release it as you slightly pull on the handle.
Once it’s released, try the machine with a coin. A lot of the Jennings have Anti Cheat parts that’s cause the machine to seize up when played without a coin.
Swami
Re: Handle Stuck
Postby midohioslotmachines » Tue Sep 03, 2024 7:39 am
Thanks so much.....Tapping it on either side made no difference, we took the mech out and it still in the half pull position.
Even tap both side lightly with a rubber mallet, with no avail. just seems to be closed.
midohioslotmachines
Re: Handle Stuck
Postby NathanHollister » Tue Sep 03, 2024 11:23 am
force down the ratchet. there should be a little bump that pokes out the front of the mechanism. this is what the handle presses on. see if you can bring it down with a wrench
NathanHollister
Re: Handle Stuck
Postby Swami » Tue Sep 03, 2024 2:05 pm
Don’t force anything…You will break it. Here’s a picture of what needs to be released. See the RED circle. Then play it with coins.
Swami
Re: Handle Stuck
Postby midohioslotmachines » Tue Sep 03, 2024 3:56 pm
The handle is un-stuck, works fine, however when I put a coin in it rejects the 50 cent everytime. coins move across the escalator normally, but still rejects coins
midohioslotmachines
re coin rejects everytime
Postby midohioslotmachines » Tue Sep 03, 2024 4:28 pm
The handle works fine, the coins reject now.
midohioslotmachines
Re: Handle Stuck
Postby midohioslotmachines » Sat Sep 07, 2024 2:54 pm
well, it started taking coins, now its not again.
midohioslotmachines
Re: Handle Stuck
Postby midohioslotmachines » Sat Sep 07, 2024 2:56 pm
well, it started taking coins, now its not again. These machines need clean for sure, They have not been out of our possession for 30
Years and now we have taken them apart to take photos.
midohioslotmachines
