bonus buzzer?
bonus buzzer?
Postby robtdix » Tue Oct 21, 2025 6:48 pm
My 1962 vintage mills has a buzzer. The machine is also missing most of the wiring and any visible method to accuvate the thing.
But somewhere, perhaps even on this forum, there was a post explaining how/where a switch can be added.
Have you any information on this?
thanks
robtdix
Re: bonus buzzer?
Postby robtdix » Wed Oct 29, 2025 10:03 pm
I found a picture of this mysteriously located switch which, it seems, would be activated when all the slides move. thoughts?
robtdix
Re: bonus buzzer?
Postby mazzeosa17 » Thu Oct 30, 2025 7:09 am
It looks like a switch to activate the buzzer only when you hit a jackpot. I say that because, based on the picture, the top payout slide's vertical post goes into the notch of the buzzer assembly. Then the buzzer will be actuated.
mazzeosa17
Re: bonus buzzer?
Postby 63mini » Thu Oct 30, 2025 7:26 am
robtdix,
mazzeosa17 is correct. My open front has the same type of setup. When the jackpot hits the buzzer goes off.
63mini
Re: bonus buzzer? thanks!
Postby robtdix » Thu Oct 30, 2025 10:51 am
thank you both gentlemen
It appears that this is something that i can create without getting too destructive.
Am I correct in thinking that the buzzer will sound until the next coin is cycled thru?
robtdix
Re: bonus buzzer?
Postby mazzeosa17 » Thu Oct 30, 2025 12:05 pm
Yes, that makes sense - the buzzer will sound until the next coin is cycled through, because the payout slides will move forward on the next cycle, opening the switch and cutting the circuit.
mazzeosa17
