Mills QT Smoker Paint Color
Postby bkrsdoz » Sat Nov 29, 2025 8:40 am
I am restoring a Mills QT Smoker that had the front casting stripped.
I know the color should be a brown with a textured or hammered finish.
Does anyone have experience with a Rustoleum color textured or hammered that would be a close match?
I have polished up the relief casting details, and am ready to start painting.
Thanks, Bob
Mills Smoker
bkrsdoz
Re: Mills QT Smoker Paint Color
Postby radiorich123 » Sat Nov 29, 2025 9:25 am
Rustolium hammer tone is a little trick to get it right. Practice first to see if you like first on scrap metal.
Postby radiorich123 » Sat Nov 29, 2025 9:27 am
Did this one in regular rustolium paint.
Postby oldpinguy » Sat Nov 29, 2025 10:35 am
I found the Rustoleum hammertone very tricky to work with. Sometimes I got no hammer effect. So, Practice then practice again until you are confident you have it controlled.
oldpinguy
Postby capt7310 » Sat Nov 29, 2025 11:28 am
I agree with oldpinguy, I have used several colors of Hammered Finish paint and found the best results for me was to apply a light coat let dry, and then another light coat, I have had pretty good results. I would defiantly try on a practice piece of metal and apply a coat and see if the finish comes up to what you're looking for. Good luck.
capt7310
Postby bkrsdoz » Wed Dec 03, 2025 7:41 am
Radiorich,
I am curious what Rustoleum color you chose to repaint the Brown Front?
I am trying to decide on a brown for my Smoker.
I like the Rustoleum flat Brown, but I don't know if the casting itself will show enough texture.
I was thinking maybe do a texture paint underneath, then the flat Brown over that, then a satin clear?
How do I remove all of that from the relief design afterwards?
I was thinking a clean white t shirt with just a little lacquer thinner and my finger tip?
Tedious, but I want to do the best I can.
I was lucky to find it!
Bob (bkrsdoz)
bkrsdoz
bkrsdoz
Postby radiorich123 » Wed Dec 03, 2025 8:11 am
It was Rustoleum leather brown.
