RameGoom wrote:Update: I did have to move the star wheel on the No. 1 reel to get the stops to align properly. That wheel was pinned, so I had to remove the pin and tweak it just a bit. I also bent the stop latch to the same angle as the other two...heard it "creak" and hope I didn't hurt it too much (hardened steel on those, they don't really want to bend nicely). Anyway it works perfectly now. I left the pin out and just torqued the crap out of the screws. Seems I have replaced half the screws on the whole machine because the slots were flared out from repeated misuse with a worn-out screwdriver. Too bad they didn't use Philips screws back in the day. So to be true to the machine, I used slotted screws - albeit plated instead of plain steel. Hope that didn't hurt the originality....
The other thing I found is on the No. 1 reel, there was a cherry toward the bottom of the strip that didn't align with a slot on the wheel - it should pay but never did. So, I found a guy that prints reel strips and had him replace the cherry with a lemon, printed new strips across the board. Now it works as it should. I wonder how that cherry got to be on the strip in the first place? Must've been a replacement strip at one time that someone screwed up?
