Watling Blue Seal Twin Jackpot
Re: Watling Blue Seal Twin Jackpot
Postby flipper77 » Wed Jul 31, 2013 7:10 am
Don't give up hope - there always is a solution. You can't lock the jackpot feed flap permanently as then you would never feed the coin tube. I would try to somehow attach a weak spring to the flap so that it diverts coins to jackpot some of the time. When jackpots get full, the lever that detects coins in the chute would close off the chute (I see your chute has this lever). Then coins would build up on the flap and fall through to the coin tube. Point is that now that you understand how the coin flow works, you can find some mechanical fix for it. Heck - the Watling Treasury and Rol-A-Top jackpot feed is a spring loaded flap that directs coins to jackpot until full and then weight of the coins causes them to drop to cash box. Same idea. Only challenge is how to attach a weak spring to the flap and that is relatively easy. Good luck!
Flip
flipper77
Postby flipper77 » Wed Jul 31, 2013 7:14 am
Oh - and Stephane has given lots of good info and terrific pictures. But my Twin Jackpot is ten stop and it has the same gold award threaded holes for that assembly. Think your mech is fine - bet over time an operator decided to disable the jackpot (very common practice) and took off whatever jackpot feed mechanism that your machine originally had. Your machine is fine and worth a bit more work and investment of time.
Flip
flipper77
Postby METALRAILS » Wed Jul 31, 2013 8:21 am
Hello all,
Thanks for all the replies & good info. At least I now know how it's supposed to work. Hope is not lost & I'm on it. The weakened spring is a great idea.
I might say as going through my 1st slot, I just got initiated! Lots of fun going through it, kind of like a detective. After this glitch is resolved, it'll be fully working.
Many thanks, Gene
METALRAILS
Postby gsx11r » Thu Aug 01, 2013 2:24 pm
hi
Gene , do you can remove the reel bundle and take picture from the inside of the Mech. ?
Just for see if you just need to find the jackpot part or the complet side frame !
Flipper77 , you are right , I have seen this about your gold award side frame !! Are you sure that you have the original reels bundle ? Maybe that was a 20 stop before this 10 stop ? :lol:
Stephane
gsx11r
Postby METALRAILS » Thu Aug 01, 2013 4:50 pm
Stephane, here is the pic. No place for your cam on this frame. Flip suggested that I put a weak spring on the jackpot flap, which is a good idea. That got me thinking to use a counter-weight on the flap instead. I can adjust the nuts so it operates just right. Also, I can remove it completely with no damage in case I get real lucky & find the correct set up.
Gene
METALRAILS
Postby flipper77 » Thu Aug 01, 2013 5:12 pm
Gene - the counter balance idea is terrific! Better than a weak spring by far. You have now graduated to a true antique slot fixer. You are lucky to experiment with a Watling as their mech is easier to work on than just about any other. Feels like you need three hands to pull out and especially re-install a Mills reel bundle.
Good job!
Flip
flipper77
