Jennings 1931 Victoria model B
Postby oldslotman » Sun Aug 11, 2013 6:06 pm
Can anyone show me a picture of the counting wheel setup on the side of the mechanism like the one pictured> I think I'm missing a spring or two.
Re: Jennings 1931 Victoria model B
Postby mtstanley » Mon Aug 12, 2013 6:52 am
If no one provides you a photo, I can in a couple weeks. I have a 5c Victoria B.
I will be out of town otherwise could do it sooner. Contact me sreed@rsandk.com
mtstanley
Postby oldslotman » Mon Sep 02, 2013 1:57 pm
Working fine and looking fine. Thanks for the pictures. Helped alot.
The attachment IMG_0972.JPG is no longer available
Postby Mojomickman » Thu Oct 03, 2013 12:33 am
What makes the small wheel bypass the two bumps to stop filling the jackpot once it reaches the desired notches on the mail wheel?
Mojomickman
Postby oldslotman » Thu Oct 03, 2013 12:50 pm
Mojomickman wrote:What makes the small wheel bypass the two bumps to stop filling the jackpot once it reaches the desired notches on the mail wheel?
If you look below the big wheel there is a lever about 6 inches long that reaches over to lever on the small wheel. Once the big wheel counts out the coins to go into the jackpot that longer lever is then lifted to make contact with the small lever below the small wheel. Once the two levers ends come in contact with each other the coins will no longer go in to jackpot.
Hope that helps you. I have my big wheel set at 100 coins.
Postby altort » Thu Oct 03, 2013 6:05 pm
pretty cool mech.
altort
