COCA Convention and latest find
Re: COCA Convention and latest find
Postby SLOT DYNASTY » Thu Aug 29, 2013 9:31 pm
I'm quite sure that everything will arrive undamaged, as my crew that just hijacked the truck, and is now
been diverted to Calif., handle machines with kid gloves. :D
To be fair, I will give you half of what I get for the ones I don't want to keep. :wink:
Well Dave, you finally have hit over 800 members, even though 80% are just 'lookie-loos'. Congrat's. We must be doing something right.
Postby Dave » Thu Sep 05, 2013 7:51 am
Bill:
Your crew must have screwed up :shock: because the machines were just delivered to my home in Denver.
Please compliment them on taking such good care of the machines though :D . All arrived in good shape.
Postby Dave » Thu Sep 05, 2013 10:56 pm
Well, I was able to spend a little time checking out the Chicago this afternoon.
The serial number is 40964. Anyone know what year this serial number dates the machine at?
The machine has predefined plugs which can easily be turned on to prevent some of the symbols from every being hit. 4 of them were activated. Two for the $2.50 payoff and two for the $1.25 payoff.
I looked closely at the gears and they show virtually no wear. The teeth on the main gear are razor sharp.
It still has the original wood locking bar and associate mounts which is used to secure the mechanism during shipment.
It also still has the original coin bag as well as the original two door locks and side panel lock which is used to get to the coin bag.
The finish on the wood is in very good shape. The original varnish is wearing off in a few spots.
Postby SLOT DYNASTY » Fri Sep 06, 2013 12:18 am
Dave wrote:Bill:
Dave:
My crew didn't screw up. I pulled them off the job. I got to thinking, it's not worth putting a flaw in our friendship.
You wouldn't let me forget it for a very long time. Like maybe, Forever! Besides, something else came up that was
of more importance. A barn-stash of Fey "Liberty Bell" machines in well preserved condition, was turned-up by one
of my pickers, that I had to act on immediately. More on those later. :D
Postby SLOT DYNASTY » Fri Sep 06, 2013 1:34 am
Dave:
Thanks for the serial on your new "Chicago". I will check my serial files, to see if I can place it in a specific area. It is really hard dating the Uprights,
as most paper labels that were glued inside the cases, were either scraped-up, or have come off with age. Not all Upright mfrs. placed dated labels
in the case, but Mills did on most models, but not all had a date. Being as your machine is one of the unmolested examples, it may have remnants of
original labels. Was your serial stamped into the outside upper side panels, (one or both), as well as a sticker inside the case?
I have a cigar box of 'plugs' for each Upright mfr. that placed cheater-bugs on their wheels. You don't want them on today, as the machine should be
fun-to-play. I do sometimes leave the ones on that can be flipped-over. Most Uprights that have had bugs installed, will usually always have 1 of the 2
high pays blocked, then 2 of the 4 second-to-highest blocked, then random after that. I have come across at least two machines that had both of the
high-pays plugged. Talk about tight, one of them had so many plugs, that it was a wonder any decent pay came up. And to top it all off, one even had
5 or 6 of the low 2-pays blocked. What was the point of that? It takes all kinds! :x That upper wood bar behind the coin mechanism is often missing.
Guess most operators saw no point in replacing it after they had taken a mechanism out for repairs. I put all original parts back, and if it is not there,
I will make one. I restored three uprights for other collectors, that had fallen over during the Loma Preata earthquake. A Caille "Big Six", Caille "Eclipse",
and a Mills "Chicago". The Chicago sustained the most damage to the inner head and coin mechanism, via cracks and chunks breaking off, and I figured
that the missing wood securing bar had a great deal to do with it. #-o
Postby Dave » Fri Sep 06, 2013 9:27 pm
Bill:
The serial number is stamped into the wood. It is also printed on the wood. There is also a paper inspection tag which has serial number, the last name of the person who finished the machine and also the name of the person who inspected the machine. Unfortunately, there is no date on the paper. Maybe I should to a search on the last name and contact all the people in the Chicago area that have it. Maybe I can find a son or grandson of the person who actually built the machine. How cool would that be!!!
The cheaters on this machine are like the ones that you described. They actually are spring loaded and flip around. There is also a screw hole to secure them.
