Mills Vest Pocket Slot jackpot?
Re: Mills Vest Pocket Slot jackpot?
Postby orangevw » Fri Mar 15, 2019 9:50 pm
Not sure if this is normal but it has a hole in the case in the front, one in the back door and 4 slightly larger holes on the bottom not including the normal ones for feet. I’ll add two photos with the locations circled in red.
orangevw
Postby randyvw » Sat Mar 16, 2019 12:04 am
there are no holes in mine that i can find, with the exception that mine has the valley sales jackpot mounted to the base, and i aint takin' it off to see where the holes needed to be......but those holes are definitely a clue to SOMEThin'.
randyvw
Postby dialsenden1 » Mon Mar 25, 2019 6:21 pm
I have Vest pocket with a valley sales jackpot. The highest jackpot on the flap is 20 coins. My flap has the + symbol too under the three bars and the 20.
dialsenden1
Postby Sslots » Wed May 10, 2023 11:10 pm
A few years late I know.
But there are some out there with a 70 reward card.
20 from the machine and 50 coins paid by the bar/person owning machine.
I only know of 3 people with this reward card.
Sslots
Postby flyingfred » Thu May 11, 2023 8:05 am
I never paid attention to it before this post but my Mills Vest Pocket does have an award card with a 70 jackpot.
-Fred-
flyingfred
Postby Sslots » Thu May 11, 2023 8:52 am
That's pretty cool Fred, I'll pm you
Sslots
Postby nvmos2 » Thu May 11, 2023 6:03 pm
3 bars = 70
Postby shortrackskater » Sun Jul 16, 2023 12:22 pm
The back door hole is stock and holds a small square nut and bolt which keep the machine forward in place. I have no idea what the front hole is for in yours. That's not original.
The bottom holes are stock and I'll have to look in to what they were for. I always meant to research that but just forgot!
shortrackskater
Postby 63mini » Sun Jul 16, 2023 1:59 pm
shortrackskater wrote:The back door hole is stock and holds a small square nut and bolt which keep the machine forward in place. I have no idea what the front hole is for in yours. That's not original.
In addition to what "shortrackskater" stated. The small hole in the front had a small metal pin pressed into it. This was a guide pin and there was a matching hole in the mechanism to help guide/lock it into place.
63mini
Postby shortrackskater » Mon Jul 17, 2023 9:52 am
I DO remember that pin in front now. Thanks for correcting me on that Ed. I'll try to take photos of both these areas and post later today.
shortrackskater
