Mills Vest Pocket Slot jackpot?
Re: Mills Vest Pocket Slot jackpot?
Postby orangevw » Fri Mar 15, 2019 9:50 pm
Not sure if this is normal but it has a hole in the case in the front, one in the back door and 4 slightly larger holes on the bottom not including the normal ones for feet. I’ll add two photos with the locations circled in red.
orangevw
Postby randyvw » Sat Mar 16, 2019 12:04 am
there are no holes in mine that i can find, with the exception that mine has the valley sales jackpot mounted to the base, and i aint takin' it off to see where the holes needed to be......but those holes are definitely a clue to SOMEThin'.
randyvw
Postby dialsenden1 » Mon Mar 25, 2019 6:21 pm
I have Vest pocket with a valley sales jackpot. The highest jackpot on the flap is 20 coins. My flap has the + symbol too under the three bars and the 20.
dialsenden1
Postby Sslots » Wed May 10, 2023 11:10 pm
A few years late I know.
But there are some out there with a 70 reward card.
20 from the machine and 50 coins paid by the bar/person owning machine.
I only know of 3 people with this reward card.
Sslots
Postby flyingfred » Thu May 11, 2023 8:05 am
I never paid attention to it before this post but my Mills Vest Pocket does have an award card with a 70 jackpot.
-Fred-
flyingfred
Postby Sslots » Thu May 11, 2023 8:52 am
That's pretty cool Fred, I'll pm you
Sslots
Postby nvmos2 » Thu May 11, 2023 6:03 pm
3 bars = 70
Postby shortrackskater » Sun Jul 16, 2023 12:22 pm
The back door hole is stock and holds a small square nut and bolt which keep the machine forward in place. I have no idea what the front hole is for in yours. That's not original.
The bottom holes are stock and I'll have to look in to what they were for. I always meant to research that but just forgot!
shortrackskater
Postby 63mini » Sun Jul 16, 2023 1:59 pm
shortrackskater wrote:The back door hole is stock and holds a small square nut and bolt which keep the machine forward in place. I have no idea what the front hole is for in yours. That's not original.
In addition to what "shortrackskater" stated. The small hole in the front had a small metal pin pressed into it. This was a guide pin and there was a matching hole in the mechanism to help guide/lock it into place.
63mini
Postby shortrackskater » Mon Jul 17, 2023 9:52 am
I DO remember that pin in front now. Thanks for correcting me on that Ed. I'll try to take photos of both these areas and post later today.
shortrackskater
Users browsing this forum: Google [Bot] and 5 guests
